Thanks simmode1,simmode1 wrote:I think that depends on what springs you are running. I set mine at 2f & 2r. My S-techs are too stiff in the rear IMO...
Well, I already have the KYB AGX's on the car, for now it is what I can afford and I had two blown struts already so I needed them.simmode1 wrote:S-Tech's only go 1.2 in the front and .08 in the rear. Its barely a drop at all. The problem is that the spring rates are too high for the shock valving.
If you are bound and determined to use shocks/strut/spring combo, Eibach Pro springs with Tokico Blue shocks work great. Almost a 2 inch drop and ride quality only 15% harsher than OEM new.
After having both setups, I can say it all truthfulness, I know why ppl jump ship and go with coilovers on daily drivers. They are far greater than...
I'm running stock springs on AGX's but it's an s13, so it might not apply to you. In any case, i usually run 2 in the front and 4 in the rear, and i'm quite happy with things that way. Yes, there's always room for improvement, but for a street-driven car it's more than adequate. However i am planning on getting different springs, not because i want it stiffer, but really because the front in particular is waaaay to high. I'm not too familiar with s14 spring rates/drops, but in general i think Swift springs and Tanabe GF210's are mild-drop and not too stiff to use with AGX's. Good luck.7anshin8r wrote:
Thanks simmode1,
I'm on stock springs right now. I'll get a better set of springs later, I was told by KYB the AGX's are made for the stock (OEM) spring size and not to go any lower than a 1.25" drop.
So, hearing that I decided to put OEM springs on for now, and do my research/save up some money so I can find a good set of springs close to stock size...
Having said that, is anyone besides me running OEM springs on their AGX's? And if so, what do you set yours at?
I drove to NC and back to FL again with them. I have to say on s14 stock springs I like 3 & 6 on the highway and get a looser better feel from 2 & 4 around town.wadiad wrote:
I forgot about the 4/8 split front to rear.pandapants wrote:the fronts aren't softer than the backs. the fronts just have settings from 1-4, 1 being oem and 4 being the stiffest, as the backs have settings 1-8, 1 being oem and 8 being the stiffest, . so a 4f-8r is really like ~255lbs/in front and ~255lbs/in rear or ~4.5kg/mm all around.
how is your car so slammed? Cut springs? Do the agx's lower the car at all if anything?pandapants wrote:i set mine to 4 up front and 8 out back.... and i still don't think it's stiff enough
i think it has to do with the amount of weight in the rear compared to the fronts... so the fronts should def be stiffercracker wrote:You guys are all running the rears harder than the fronts????
On my s13 with Koni's I ran the rears about half as soft as I ran the front.
My miata is the same way. I always thought on RWD, or usually any ways, that you wanted the rears softer than the fronts, on rebound anyways.
