kyb AGX questions
MikeYeeS13
Hey, I just put in my new front struts and when I turn right, I hear somthing like rubbing but intermiting sound. When I pull into the garage, on the little step up, I hear a swoosh that sounds like the shock or somthing. Any suggestions?
fiznat
Car: Grown up :(
my shocks make a little swooshy noise sometimes when they're compressing and releasing- only in the rears for me though. I asked on here and people said its just the normal sound from the oil moving through the valves on aftermarket shocks.
About the rubbing sound, why not have a friend turn your wheel while you watch down there to see whats rubbing? Did you re-install your spring coil silencers (the little plastic wrap that goes around the first couple coils on the spring)? Did you only put on your front AGXes and not the rears? Did you do new springs at all? More info!
