KW V3
JDM240SXcoupe
Car: 1992 240sx coupe
1991 Crx Si
I been searching for days without much luck. So now im planing on getting the KW V3 for my s13.I see they dont come with top hats or camber plates. So my question is, what camber plate should i use?Do i need to modified anything to make the camber plate fit? Anyone has this suspension that could help me with this. Thanks.
SX APPEAL
Car: 06 G35 Coupe 6MT
95 Maxima SE 5MT
Could always use your stock stuff if you can't locate top hats, but they're usually pretty easy to find online. As for camber plates, I've heard good things about tein, and they're readily available from FR Sport. I scored a set of used cusco's on ebay a couple of years ago, so I know they work too.
Edit: Now I'm looking at these and I see the bottom brackets on the front are slotted for camber adjustment, I might just bolt the stock top hats on all four corners and see if you really need any more adjustment
JDM240SXcoupe
1991 Crx Si
Yes I was reading and I see I an use stock top hats. But I think it would be better if I could install some camber plates. Do you know where I can find new cusco camber plates?
SX APPEAL
95 Maxima SE 5MT
Quick google search yielded: http://www.kamispeed.com/product-p/cus.220-410-s.htm
I'm sure there are other places out there that sell them to, just look around at the sponsors on this site. FR Sport and THmotorsports are a couple of good ones
JDM240SXcoupe
1991 Crx Si
Ok decided to go with tein front camber plates. I found a link with them on the kw v3. Seems like I need to cut the spacer. Anyone did this?
http://www.nissanroadracing.com/showthread.php?t=1246
AAV240sx
Car: '89 240sx ka24e-t
E39 M5
KW makes camber plates for their shocks, best bet would have been to order those.
JDM240SXcoupe
1991 Crx Si
I read something on them wanting 600 :blush: for them. Ill look on their website tho.
JDM240SXcoupe
1991 Crx Si
Kw doesn't have them for sell.any ides? Anyone have this coilovers with camber plates?
