Kts coilovers group buy and different spring rates question
jprandkpr
Car: 91 240sx
Hi again. We have a 91 s13 with kyb gr2 shocks and stock springs. Wanted a little lower so read through the forums here and decided to go with tein lowering springs. After finding out about the kts coilovers group buy $999 shipped, changed mind and decided to go that route. I know I'm a noob and this car is mainly used for dd but we race motocross for 5 years now so we think suspension is higher priority than motor is. Also the ability to fine tune is kuul if I take the time to read/learn. Anyway my question is are the 8/6 springs ok for street? There's a possibility to get 7/5 springs instead. Or should I just not worry about it? In outdoor mx our best suspension tuning was with the plushest setup that didn't bottom,as proved by lap timers. We'd run with softer compression and tighten up rebound for each track. Supercross settings are firmer both compression and rebound but I hope I don't jump any triples in the 240. At least not on purpose. After all some of these CA roads are like mx tracks so maybe some of these principles crossover.
240sxjeff
Car: nissan 240sx zenki version
Yeah you should be fine with 8/6. If its too stiff you can always set the dampers a little softer.8/6 is perfectly fine for me but we most likely have differnt driving styles
naed240sx
Car: .....
I've got kts. 8/6 is fine for the street, but I would probably prefer 7/5. They have 15 way adjustable dampers, which go anywhere from being slightly underdamped for the springs to being rock hard. As far as adjusting compression and rebound separately, that's unfortunately not possible. They are adjusted in unison with the single knob, as are most <1500 coilover setups.
As far as the group buy, that is a very good price, but I would be sure to make sure that the company offering them is still offereing warranties and rebuild policies. http://www.splparts.com warranties kts for a year, and after that, if you blow them you can buy 4 new shocks for about half the price of the entire setup.
jprandkpr
Car: 91 240sx
Hey thanks for the info. I'll check into the warranty stuff and I obviously didn't research enuf into the compression and rebound adjustments. I still like the kts though especially since i can't afford much more.
naed240sx
Car: .....
jprandkpr wrote:Hey thanks for the info. I'll check into the warranty stuff and I obviously didn't research enuf into the compression and rebound adjustments. I still like the kts though especially since i can't afford much more.
Yeah they are great coilovers. I have no complaints. Definately best for the money from what I have heard. You just want to make sure they are well backed. I wouldn't want to be stuck with some co's that I couldn't rebuild.
McRussellPants
Car: 92 240SX
They also sell 9/7s
an 10/8s are just as easy... which is what I'll be getting
Nismo_Freak
Car: 89 Nissan 240SX
jprandkpr wrote:Hi again. We have a 91 s13 with kyb gr2 shocks and stock springs. Wanted a little lower so read through the forums here and decided to go with tein lowering springs. After finding out about the kts coilovers group buy $999 shipped, changed mind and decided to go that route. I know I'm a noob and this car is mainly used for dd but we race motocross for 5 years now so we think suspension is higher priority than motor is. Also the ability to fine tune is kuul if I take the time to read/learn. Anyway my question is are the 8/6 springs ok for street? There's a possibility to get 7/5 springs instead. Or should I just not worry about it? In outdoor mx our best suspension tuning was with the plushest setup that didn't bottom,as proved by lap timers. We'd run with softer compression and tighten up rebound for each track. Supercross settings are firmer both compression and rebound but I hope I don't jump any triples in the 240. At least not on purpose. After all some of these CA roads are like mx tracks so maybe some of these principles crossover.
You can't compare motorcycle suspension with automotive suspension. You have a much more complex situation in a car, and even between one car to the next you will find two good sized variations in valving optimization.
I would suggest reading up on it and forgetting what works on a motorcycle.
ReD*PiG
Car: 1990 240sx SRpowerd
Is there a group but on these right now? if so I am in.Let me know.So 9/7 are I deal for daily driving?Thanks......
naed240sx
Car: .....
ReD*PiG wrote:Is there a group but on these right now? if so I am in.Let me know.So 9/7 are I deal for daily driving?Thanks......
It's all opinion. Softer is more comfortable, but stiffer yields better response. I am on 8/6, but would prefer 7/5 for daily.
ReD*PiG
Hey naed240sx,is 7/5 still firmer than stock?Thanks,I don't want it to be to soft.Thanks
nismofly
Car: 89 Nissan 240SX Hatch
stock is 2/2, so yes, theyre stiffer by far
ReD*PiG
Ok,Thanks......
Nismo_Freak
There's no group buy that I am aware of.
McRussellPants
Car: 92 240SX
MSL is always having KTS group buys.
SPL is still has the better warranty though.
ReD*PiG
Thanks Russell,Who is MSL?Just curious, I will most likley be going with SPL.
chmercer
thoes dudes that scammed all thoes people on the 1300$ sr20 group buy on zilvia, lol
Juujai
support kuah. way better service. screw the 100 bucks you save at msl. it takes what 2-5months to arrive. when kuah will take care of you in like 2-3days... if you break anything no questions asked overnight air mail. thats ownage right there
ReD*PiG
who is kuah?
naed240sx
Car: .....
ReD*PiG wrote:who is kuah?
Kuah is the man behind SPL parts. You obviously have never delt with spl.
94_240sx
Car: 94_240SX
Had a chat with SPL guy(must have been Kuah) and asked about 7/5 rate coilovers. He said I'll have to buy a brand new set of 7/5 rate springs and swap them myself. Coilovers still come with 6/8, and SPL won't replace springs for you. Please correct me if I'm wrong.
He also mentioned that 6/8 is not that bad for daily driver. I'm getting KTS coilovers in a couple of months and I won't buy a set of 7/5 springs($100+). I'll definitely buy directly from SPL. Can't wait or take risk...
ReD*PiG
Hey naed240sx,are those kts coilovers you are running?Also How do they ride HONESTLY at that ride height on the street?Settings please........Thanks.Looks Great!
ReD*PiG
Nevermind,I just read your post up top.
naed240sx
Car: .....
ReD*PiG wrote:Hey naed240sx,are those kts coilovers you are running?Also How do they ride HONESTLY at that ride height on the street?Settings please........Thanks.Looks Great!
Yeah I am running kts. 8/6 spring rates. Obviously, they are MUCH stiffer than stock, considering that stock rates are 2/2. They only feel too stiff when driving over really bumpy roads. Highways are very smooth, and on any other decent well maintained roads, you won't really feel much of a difference untill you start cornering hard (at this point you will notice the huge decrease in body roll). They aren't bad on the street, you just have to go slower over rough roads. Never had a girl complain either, so they can't be that bad.
As far as you mentioning ride height:
Ride height has nothing to do with ride quality when you are on coilovers. The shocks maintain full travel, no matter how much you lower with them, unless you start drooping the springs(only neccesary if you want to start tucking tire in the rear). My car is just as comfortable at this height as it was when it was 2 inches higher with the kts.
Hope this helps.
Bosrudorfer
Car: S14
I wish SPL had a group buy or even a sale. I would buy one in a heart beat. I'm holding back now for several reasons.
ReD*PiG
Thanks alot naed240sx,Thats great that you haven't had any girls complain Thats the perfect test.There always the first ones to complain.....Lol.As far as the kts coilovers go I would love to get a set;but there a little out of my range.So I am going with the megan's.I know for a couple of hundred more I can get the kts.But the wife is talking trash already!So do you think there is a big diffrence between the kts and the megan.Also what(cheaper) coilover would YOU go with If you didn't get the KTS?Thanks again...
naed240sx
Car: .....
ReD*PiG wrote:Thanks alot naed240sx,Thats great that you haven't had any girls complain Thats the perfect test.There always the first ones to complain.....Lol.As far as the kts coilovers go I would love to get a set;but there a little out of my range.So I am going with the megan's.I know for a couple of hundred more I can get the kts.But the wife is talking trash already!So do you think there is a big diffrence between the kts and the megan.Also what(cheaper) coilover would YOU go with If you didn't get the KTS?Thanks again...
Everybody just tells me that megans have pretty crappy damping compared to kts. Never driven in a car with them personally.
I also haven't heard of a rebuild policy for them. If you blow your kts, it's 550 for ALL NEW dampers. Best deal around.
