Thanks but I wont need it anymore. I have everything perfect now. I used zip ties to make sure I had enough travel (the fronts had plenty because I have good amount of preload but the rears with zero preload where bottoming out so I increased the preload until I had enough travel).Bronze MFP wrote:if you have an s14 i can give you my measurements i'm currently running.
The zip tie ended up at the upper mountnaed240sx wrote:There is no way you were bottoming out your rear shocks running a captive spring. People run like 10+mm droop and don't have problems.
In actuality, neither preload or drooping the spring shortens the stroke/travel. The shock travel is going to stay the same. The only thing you can change is the amount of compression travel and rebound travel. People don't often enough discuss these when discussing travel. Of course the sum of the compression and rebound travel amounts will always be equal to the same number(the total damper stroke).sdwyzs14 wrote:preload doesnt shorten the shock stroke it stays the same only it makes the shock work harder to compress. you're thinking about lowering the car by loosening the lower perch so that the shock compresses a little before it comes to rest on the spring
Preload lengthens compression travel and reduces rebound travel.
Sagging lengthens rebound travel and reduces compression travel.
Preload doesn't really make it harder for the suspension to compress, unless you are running progressive springs. The force on the car from the coilover assembly will still be the same when the car is static, and it won't affect spring stiffness, so body roll won't really change.
I'm pretty sure this is what you were trying to say. Just thought I would expand that thought a bit.
DDGSXR: Preload is generally measured in millimeters. If you move the spring perch up 10mm from the captive point, you are running 10mm of preload. If the spring rate is 8kg/mm, you have now effectively created 80 pounds of force in the spring.
Preload is used to adjust corner weights.ddgsxr504 wrote:So what your saying is that I need to corner weight my car to figure out what preload I should be running? My ride is a little stiff and I was wondering if there was a way for me to fix that a little. I know that coilovers are not intended for street use but surely there is a little tweaking that can be done.
First sentence is correct, except that "travel" should read "compression travel"Bosrudorfer wrote:What about this?
"Which method should you use? Preloading the spring allows more stroke/travel for the shock, which is very important; if the shock stroke/travel is too short you will be constantly hitting the bump stop. However, preloading the spring too much can create problems - it would become easier for the tire to lift off the ground when the weight transfers away from that corner, and it would also effectively increase the spring rate."
Hmm makes sense. Well you should inform Kuah from SPL to correct his install guide then.naed240sx wrote:
Preloading does make it easier to lift wheels.
Preloading doesn't increase the spring rate. The spring rate is constant for most typical springs. You can't change it without changing the spring.
