I'm gonna chime in really late as I missed this the first time around.
First off, this is a really big turbo for the KA. I can't recall the various flowrates for the KA at different RPM's, but my initial though it that much (If not most or all) of the KA's airflow range is in front of the surgeline. This means, if you try and run a turbine that is small enough to allow it to spool at a more reasonable RPM, you'll probably get surge and kill the turbo. Or, you leave the turbine large and end up with a huge amount of lag and a very short powerband (You'll likely hit redline before getting much out of the boost). This is more typical of a dyno queen.
driftin_sr20det wrote:Of course it can work. Its really not THAT big of a turbo, look at all these guys running those giant holset's with much bigger exhaust a/r's than .68.
A/R ratiois only one aspect of a turbine. You also have to consider the turbine size AND trim as well. All three affect flow, efficiency and its ability to drive a compressor. For example, a T4 turbine of any trim with a .68 A/R will behave much differently than a T3 turbine of any trim with the same A/R. That said, no direct comparison can be made between different turbos based solely on the A/R ratios.
