ksport install Q's
Axel Grungy
Car: 2001 G20 5spd
ok i just installed my ksports tonight. i havent drove it yet and im still tinkering with the ride height (PITA) what is up with the camber plates?? im confused about the increments of the marks, how many marks is a degree?? also on the front lower mounts, the top bolt hole is eccentric?? where should i set it at?? i mean i know teh basics but they should at least come with SOME info...
Exar-Kun
Car: 2005 350Z
Info adds 300 dollars to the coilover cost. the markings are refference points more than anything, from what I've noticed at NTB. the ammount of camber you'll get from mark to mark will vary a small bit depending on ride height and other things.
Also, i ahve no idea why the top bolt would be eccentric unless its supposed to be its own small camber adjustment for smallr adjustments later..?
-CHet
chmercer
yes, the top bolt hole on the shock mount is such that you can add more or less caster depending on how you bolt the shock on.
808DRFTR
Car: 89 240sx KA24DE Swap
91 240sx SR20DET Swap
02 Sentra SER Spec V
01 QX4 4x4 Lifted
01 I30
11 M56 Sport
When I did mine I left the upper camber plate as is. I adjusted the lower mount all out (pos. camber) and came to -1.0 for the front which was in spec.
