here's a basic write up.
- brake lines fabbed
- mount bracket fabbed
- ksport bolted down
- lines ran
- line brackets fabbed and mounted
ran out of light; didnt have time to install the lines and bleed the system; next week.
pics:
mount bracket:
a 1/4" piece of 8x5 aluminum that i found around my dad's house; good to have a father that use to be a commercial shrimper
ss brake lines:
IN -7/16"unf 90* bend with a 90" m12x1 - 6' of line
OUT - 3/8"unf 90* bend with a 90" m12x1 - 7' of line
***UPDATE***
last update was nov. 18 2010, i've driven the car daily...drove it to houston on nov. 28 for a drift event, drove home, and have been driving and having fun with the car ever since. I'm from new orleans...
***important bleeding proceedure***
since the last update, all i did was bleed the system according to fsm, but before then, i had to unbolt the ksport and flip it right side up so that no air would be trapped in the master when bleeding.
before driving to houston, all i did was secure the lines with some radiator hosing so that they wouldnt rubb n cheff after some time.
also removed all of the oem ebrake parts.
lines, shoes, clips, springs, evvrything!
