tokidokiid »
https://forums.nicoclub.com/tokidokiid-u92079.html
Mon May 12, 2008 9:19 am
yeah u guys are right i meant 400/600. i bought the car w.98k miles on it and replaced the oil and filters, ect sensor, apart from that idk how it was before. i had a local mechanic change the ks since it was a hassle for me, but i did double check all the hoses n connections around the throttle/intake area and they all look fine. except for one hose that sticks out from the engine but im pretty sure its a breather hose? i took pictures that i will post once i am home tonight.
i fixed the idle problem though, i read somewhere in the forum about adjusting a screw to changed the idle so i looked for it and on my first attempt i found it, i loosened it to idle at 900 and now it all works fine. is it possible the mechanic tightened it to make me come back or can it be anything else that will come back to bite me in the *** eventually
