VStar650CL »
https://forums.nicoclub.com/vstar650cl-u299034.html
Fri Feb 13, 2026 11:03 am
If jumping the relay makes it run then that's pretty conclusive, the circuit is just a relay and the pump. No rocket science, the relay either 1) is bad or has high resistance, or 2) isn't being turned on. First check fuse #17 which supplies the relay. If that's good, make sure there's power at 2 and 3, otherwise you have a wiring problem between the fuse and relay. If that's good, if there's a similar relay in the box, try swapping them. If not, put 12V and ground across the coil terminals 1-2 and see if it clicks. If it doesn't, the coil is bad. If it does, ohm terminals 3~5 while the coil is powered, you should show under 1 ohm. If it's higher, the contacts are shot. If the relay checks good then rig a test lamp between battery+ and pin 1 and have an assistant turn the key from off to on, the lamp should light for about 1.5 seconds when the pump primes. If it doesn't, either your ECM is shot or the wire between the ECM and the relay has a problem.
