I completed the black and red wire solder on the OK PWB but now I am stuck - help please,,,,
Do I have the correct connectors or ....?
Any one of you have done this mod might have the answer- here are few shots
I already installed it... if you need help let me know.cereal2k wrote:Good tips and link to the FSM. Thanks.
I'm red/green color blind, when the time comes I'll get a shop to do this
I appreciate that LOLcmesurf wrote:I already installed it... if you need help let me know.cereal2k wrote:Good tips and link to the FSM. Thanks.
No Downside - VSS breaking - it still is connected unless you want to use unavailable commands while you are driving.SteveTheTech wrote:Is there a downside to breaking the VSS?
Why didn't you get the swap in unit?
How is it activated?
All you said is true but these module can be removed/disconnected and you are back to OE config. I am with you , I am not a fan of the after market stuff but after all the pros-cons-I decided on two KPT module, single touch *actually double click) for roof and the Nav bypass...so far modules are functioning ok and I always have OE config if I want to ignore the module's functionality. The self install module do give you advantage that you know how to remove them easily.SteveTheTech wrote:I was particularly wondering about calculation of fuel econ, or those stupid ambiguous maintenance indicators.
On another website (which shall remain nameless) I found someone talking about swapping out the buttons and center dial assembly with one they have updated.
If I were going to do this I would try going through the CF slot and into the operation software and remove the requirement written on the HDD. I'm really curious about these timed switches that are hardwired in such a way. Theoretically I like KPs technology but like many other addons I am not completely sold on their long term durability. I have seen many alarms and remote starters fail and have some very unintended consequences. For me this is kind of research.
I have a client that has an older QX that has some window modules that are the one touch up, but it was added to a truck that has OE full auto. Well after 4 years the modules started to act up caused all types of body control issues. These kinds of add ons tend to neglect diodes that are typically found in OE control units, or the OE control unit is not tested to withstand longterm exposure to unknown simulated signals. This happens more so in digital pulse signals and RGB lines, just like in home theater.
It's been long while ago but here are the connectionscereal2k wrote:Cmesurf, what were the tipss, tricks or pics to get this module installed on the vert? We are having a mod day this Saturday and figured this would be great to get installed. What differs on the instructions that came with the module? Thanks.
