Cgeigert »
https://forums.nicoclub.com/cgeigert-u48530.html
Wed Aug 29, 2012 9:55 am
About time to install the Koyo and Altima fans in 89 with SR and AC removed. I've read some different threads about installs, and using the AC wiring, etc. What's the best way to wire for consistent temps for track car. If I were to get a dual fan controller is there a good easy to use one. The Dif one is NLA and I heard it was hard to use. I'm thinking it might be easier to hard wire one fan into the AC wiring then use an adjustable controller to set the other one to come on around 180. Is the AC wiring enough amps for both fans? Any help is appreciated. Also, with Koyo and Altima fans does the stock intercooler cold pipe fit across it?
