Koyo Radiator-S13 Install Issues? Informal Poll
volkl77
Anyone that has installed the KA24DE/S13 version of the Koyo radiator... Can you share your experience!
I've just gone through a month long ordeal with another "OEM" fit radiator that was definitely not oem fit. In my case the mount posts were incorrectly located on the tanks... off by a good 1/2", causing the lower tank to hit the rad support.
hondahunter180
Car: 2003 audi a4 - 1969 bmw 2002 - 1990 s13 (sold)
ive installed one on an s13 w/ a sr20, it was VERY streght foreward installed almost as easilly as a stock one. the only thing was it was much wider than the stock one so it was a little bit more difficult to get into position. other than that everything was fine, the fan shroud even fit nicely. i used zip ties to hold it on but i think the factory hardware should work fine. one thing though, if i remember correctly, it came with cardboard taped to protect the fins i would leave that on untill you have test fitted it and you are ready to install to keep it in good condition. good luck.
slipnfall
Car: '06 D40
Is this the Koyo Performance radiator?(like 2.1" thick), or the OEM replacement version?(~5/8" thick).
llamabeta
It is much thicker than the stock version. 55mm so yes 2.1 inches
