asoomal »
https://forums.nicoclub.com/asoomal-u90618.html
Tue Apr 05, 2011 6:25 pm
Hey guys, I recently installed a new Koyo twin row on my stock KA (stock rad took a poop, gonna need the Koyo anyways in the future) with the stock fan clutch and shroud.
When I installed the Koyo radiator, I also installed a new OEM water pump and a new OEM fan clutch.
The problem I'm having is that the engine temperature needle won't budge at all unless I stick some cardboard in front of it. I used Nissan DataScan to monitor temperatures and it wouldn't go above 45C. I then stuck some cardboard in front of the radiator and was able to get around 60ish C, still not hot enough to open the thermostat.
It's an OEM Thermostat.
I've also removed the A/C condenser cause it was damaged beyond any repair and checked the thermostat too. The thermostat was closed when I took it out and was able to get it to open at around 75ish C.
It was around 10C, or 50ishF today outside.
Anyone else having this problem?
Edit: Also, I doubt it's the temp sensors, I have no heat.
