koyo radiator leak
S13silviaboy
Car: 240sx
my radiator is leaking really bad, i think its comming from the seal at the bottom, on the right side(if your looking at the engine). i filled it up last night and this morning coolant was all over the ground, just keeps leaking, plz help
homeslicej2
Car: 1990 Nissan 240SX S13 SR'd hatch
That side is where the drain plug is located. Make sure it hasn't worked itself loose. Crank the car, pop the hood, and then watch to see where it's leaking. Then go from there.
S13silviaboy
Car: 240sx
i looked at it and i figured out that it was the nipple that is leaking, does anyone know where i can find one, and is it hard to change?
homeslicej2
Can you take some pics and post them please?
S13silviaboy
Car: 240sx
yea, but i finally took out the radiator today and found out it was not the nipple, it was actually the weld on the left side next to the lower radiator hose, so i need to get it rewelded, has anyone else had this problem?
homeslicej2
That sucks. I haven't, but my koyo is only ~4 months/2k miles old too. Post some pics to show us where the weld failed so the rest of us have a visual reference remember to keep an eye on it.
Luke
Oh this is not good news to start hearing people having the same problem. I noticed I was leaking coolant right around the bottom right next to the drain plug. I thought maybe that was what was leaking but found it was near the welds like this other guy. It doesn't leak profusely, just drips from time to time.
Nismotouched
weld the hole, drill and tap and new drain hole and then you will know its done right
MagnumP_I
Car: 1993 240sx
Wow I just bought my friends 240 and theres a Koyo Radiator on it an it was leaking like crazy I was going to take it out Fri to see if I could find prob as of now Ive resorted to filling up with water everyday since its nice out you guys dont think that will mess up anything right until friday as far as water like causing rust or something Im new to this thanks for any assistance.
codyace
Car: S14 w/redtop
9/10 times it's that ****ty plastic plug leaking over to the corner.
Kalypso
S13silviaboy wrote:yea, but i finally took out the radiator today and found out it was not the nipple, it was actually the weld on the left side next to the lower radiator hose, so i need to get it rewelded, has anyone else had this problem?
I HAD THIS EXACT PROBLEM. I dont know how it got there, it was a tiny whole inside a deep dent. It wasnt my plug.
I lost faith in koyo after that happened, I know us a Visteon. JB weld couldnt contain the leaking.
i replaced the koyo before I took it to a radiator shop, a tack weld might have fixed it.
good luck!
T-rev
I know this is an old thread, just bumping it back up to see what ever happend in the end
I was gonna get a koyo for this summer but now I dont know
Kalypso
Koyo... is still the best.
but there are a lot of highly respectable companies that deserve respect.
C&R (by visteon) and Griffin radiators. made in the USA and race tested for decades.
89'240sx
Car: 89'240sx
ok... so im new to this but i have a koyo radiator and i have just started to drive my 240sx after my long drawn out swap... is there something i should know about my rad? is this a reocuring thing?? or were some people just careless with their radiator?
codyace
Car: S14 w/redtop
Koyo is safe, and has been safe forever. Some of these occurances are just that, occurances (as could be had with any product)
T-rev
codyace wrote:Koyo is safe, and has been safe forever. Some of these occurances are just that, occurances (as could be had with any product)
Thats what I was looking for
Kalypso
89’240sx wrote:is this a reocuring thing?? or were some people just careless with their radiator?
these stories only happen because so many people use koyo. out of the masses 2 or 3 will have problems.
mine look damaged because someone slammed it against the core support while installing it. that gash turned into a leak.
but I am excited to start using my C&R. They are race tested and its nice to use something outside of the norm
89'240sx
Car: 89'240sx
wikid awesome! thanks guys i was worried there for a moment...
