RB_Seth wrote:I put my fans where the a/c condenser was, just trimmed them and stuffed them in. I was going to put them on the engine side but that would require me to trim the guards around the fans and the crank pulley might still be in the way because i dont know how much the blades would flex when they are on. The rad just drops in, and i used thick foam to make sure the fans blew all the air thru the rad. hope that helps, if i think about it i'll take a pic of where i cut for the i/c pipe
hey, where did you put that foam at? what kind of foam are you talking about?
