koyo and flexs (pics)
krayton
Well here it is. I've been running through a bunch of setups and this is hitting the end of the straw.
warning to a few, this is overkill for most of you. most people can do fine with a stock radiator and one puller (all i could fit)
my engine is sitting forward like anyone using the r33 crossmember
i cut the support a bit. the pulley has rubbed a bit on the heat protection shield on the flex. but the brackets i made for the radiator arent tight enough. so thatll be a fixed problem soon.
as for performance. i really wont be able to test this to the full extent till the desert heat picks up and i get back on the bigger tracks we have here in town.
im goining to get a thermo switch soon because i cant get the car to operating temps in arizona's 70-80 degree winter weather.
NISMO_RB25
Car: 1992 240SX with RB25DET, 1987 RX-7 TII
You can also gain a small amount of clearance by removing the plate on the back of the fan that says FAL. You have to pull the fan out, but it only takes a few minutes and gives you about half an inch clearance. I had them that way when I had the stock radiator and dual pullers.
Yellow4g63
Car: 95 Nissan RB20 240SX RB20
91 Nissan NX2000 VE power
95 Nissan 240SX Stock
I took off the rubber around the felxi's on mine. Didn't think to take of the back plate. The PS might fit if I do.
420_240
I removed the plate and had just enough room to fit the RB radiator and FAL 220's with about an 1/8th inch of clearance between the fan and pulley
