homeslicej2 »
https://forums.nicoclub.com/homeslicej2-u54419.html
Mon Apr 09, 2007 7:18 am
Moral of the story.
Copper radiators do conduct heat better and disperse it better than aluminum. However, the lead soldering used to join the copper core piping in the rad is as we all know, a piss-poor conductor of heat and makes the copper rad less efficient at conducting and dispersing heat than an all aluminum rad. Go with the alum one. If you get the copper it may work fine, but if not then you either have to spend more money on other cooling accessories or buy an alum one, so save yourself the trouble and money and buy the alum one. Oh yeah, the others are right when they say that the copper one will be more prone to corrosion and need flushing more regularly to maintain efficiency.
