Kouki Taillights
s14driver2.4
Car: 95 nissan 240sx
thanks shusaka,and as for this topic does anyone know where i can get kouki tails for my s14 they are beautiful and ive been looking at ebay but i didnt know if any of you guys knew of another "better" source not that ebay is bad im just curious if there are other sources out there that arent ungodly expensive,thanks guys
S14toRPS13
wynnEZ wrote:The lower trim piece isnt going to fix his 1/2 inch gap at the top of the light though guys...
Yes, it will. The 240sx lower trim piece isn't shaped right to allow his tailights to sit in all the way. When I was using the original lower trim, I had to modify it a bit in order for the lights to sit in closer to the body.
S13_love
Too much sealant? Thats my only guess.
Be careful on how much you try to tighten the taillights, i tried that with my stock ones and stripped one of the studs
Let me tell you, that was no fun at all to take care of...i ended up pulling the stud out of the taillight and had to glue it back in.
presidential
Car: 1992 240sx hatch, 1993 240sx coupe
Obtain a rubber mallet.
Remove tail lights.
"Massage" the sheetmetal as your car has probably been hit.
Re-install lights.
Be a man and put a little a** into them.
End.
This isn't Nissan specific stuff, it's general automotive knowledge and problem solving. If something doesn't fit, find the cause and correct it. Frankly, I'd be embarrassed if I posted this.
cwilson93
presidential wrote:Obtain a rubber mallet.
Remove tail lights.
Re-install lights.
End.
actually, it is nissan specific.... without the kouki lower trim piece, they won't sit right. And no, my car has not been hit..... i found the cause, the trim piece, and i have plan on fixing it.........
i would be embarrassed if i posted telling someone to beat on their car with a mallet when they could do something alot easier and not look like a dumbass doing it.
wynnEZ
Car: 90 240 CA POWA!
My bad, I retract my statement.
sebazztard
Car: 1992 Nissan 240sx rb25det project. 2000 Honda Accord LX DD. 1992 Nissan 300zx NA.
from whats been stated and looking at the pics, i def agree with the garnish being the problem. try removing the garnish and see how much room you gain with the taillights now that its not getting caught on the bottom. def should fix the problem. keep us posted.
cwilson93
alright.... sadly, it looks like my hardware has come OUT OF the tail light So does anyone know where i can buy JUST the hardware for the kouki tails?
Nacho_240
Car: 1991 240sx LE
S13FTMFW wrote:alright.... sadly, it looks like my hardware has come OUT OF the tail light So does anyone know where i can buy JUST the hardware for the kouki tails?
Why didn't you listen to this guy?
elvis240sx wrote:DO NOT continue to tighten them down, the studs are only molded into plastic. Very expensive pieces of plastic, by the way.
cwilson93
im not the one who pulled them out.... i beleive someone tried to steal my lights last night...... buts its all good...under further inspection, the studs are all in tact so they will be getting epoxied back into the lights tonight. (yes i will be careful) lol
cwilson93
FIXED!
i epoxied the studs back in... bolted that s*** up, and now there's barely even a gap!
im assuming that the studs had been working their way out for awhile, that's where my original gap came from... It looks clean now!
Pics tomorrow!
QuicksilverFX
if i had the money i would get clear corners kouki LED tails, too bad there $2000 lol
http://clearcorners.com/produc...btail/
