EfiniRX7 »
https://forums.nicoclub.com/efinirx7-u88113.html
Thu Jul 08, 2010 7:56 am
Im also talking about the oem skirts. I know they have a ton of clip mounting points. If you want your skirts to fall off and flap around use double sided tape. I removed all of the clips from the skirts and bought washers and rivets. The zenkie does not have the holes for the clips like the kouki any ways. I have the factory hole in my front fender to line up the skirts making sure they are in the right place. Then Im going to drill a rivet size hole where the tabs would be on a real kouki. I will then use a washer since the tab holes are square and rivets are round, making sure the rivet does not pull through. The skirts will be solid just like a real kouki. If you use double sided tape be prepared for them to flap around and fall off in a month. Good luck
