Hi, I'm doing a '97 s14 kouki sr20det into a '92 240sx swap and have ran into a couple problems.
1st problem is an electrical issue. the parking brake light/seatbelt/door light on the cluster stays on even after the key is out of the ignition. also when the key is out, the seatbelts will still go on and off when you open the door. possible ground problem?
2nd problem car runs like ***. we believe it's running rich. we did not find any coolant temp sensors in our harness done by heavy throttle. could this cause our problem? the fuel gauge and coolant temp gauge aren't working at all also.
what do u guys think it oould be? any input is appreciated. thanks alot
