kouki headlights
BryanGrigsby
Car: Red 240sx SE
Where would I look on how to remove these things. Chilton manual doesn't say. I started trying to remove yesterday but they have a couple of bolts connecting to corner lights, that I can't get to from the top. I need to remove the corner lights to undo two bolts connecting the headlights to frame on the side? The corner lights seem to have a single bolt connecting it to the side of the headlight. I dont want to tear it up.
All I am really trying to do is put some new bulbs in the low beams.
NISTECH
You should be able to access the bulbs from inside the engine compartment with out removing the light assembly. You may need to remove the battery or the airbox,but that is how you replace bulbs.
BryanGrigsby
Car: Red 240sx SE
Man, thanks for helping me out so early in the morning out there. Its early on the East Coast!
I thought you might say that, removing batt and airbox.
Im gonna see what I can find on maybe an exploded view of the front assembly, I am considering inserting some HIDs. That Chilton manual is worthless for my car when it comes to 97-98 specific stuff.
NISTECH
ok well after you remove the single screw that holds in the marker light to your headlight ,you have to pop it out with a bit of force. It is snapped into a plastic bushing in the fender.
BryanGrigsby
Car: Red 240sx SE
AAAHHHH. OK. I didnt want to rip it off, but this was also my suspicion. Left me scratching my head. Cool man, thanks alot for the help. You solved my problem.
