Kouki Headlight Wiring To Zenki Harnest??? Help!
Buck01
Car: 1996 240sx SE (Kouki)
Hey nico im kinda confused, I doin the front end conversion but my zenki headlight connecters are differnt from the houki headlight terminals. Do I got to cut my old connectors and splice and wire kouki ones so they'll fit the kouki headlight? And what do i do about the Low and high beams since the kouki headlights have 2 bulbs(for low and high) opposed to the zenki dual fillament bulb(low and high beam in 1 bulb)??. Need some help nice please...Thanks :gotme
motoman399
Car: 98' wrecked (RHD coming soon) 240
i thought i told you about the relay you have to wire to get the low beam to stay on.
yes you have to cut your factory low beam wire and splice in the kouki wiring. its pretty easy.
if you need more help just ask.
Buck01
Ok motoman cool...so i gotta get the kouki headlight terminals and splice it to my zenki headlight harnest then connect to the kouki headlight(low-beam),...then run a relay from the low beam wire to the high beam bulb splicing and putting on kouki high-beam terminals as well???
motoman399
not exactly...
you will need to cut your zenki low beam harness and find the low beam and ground wires. you then connect those to the low beam on the kouki headlight. then you get a relay, hook up your constant power and constant ground with a fuse and then you take the remaining high beam wire from your zenki (low beam) harness and you run it to the relay. from there you take the remaining pin of the relay and run it back to the low beam wire of the kouki light.
that makes it so that when you turn on the high beam it activates the relay and in turn keeps the kouki low beam staying on. we discussed it in the kouki check in, ill see if i can find the page.
motoman399
found the page..
kouki-check-in-s14-t254807-4160.html
and check this diagram, its also in the kouki check in..
http://www.classictruckshop.com/clubs/e ... oglite.jpg
Buck01
Ok I'm using the oem healdlight/highbeam so that shouldn't be a problem to what your saying right?...and thanks for the help motoman
motoman399
no i have done exactly what you are trying to do twice. once on my car when i converted to a zenki haness in my kouki and ones in my ex's zenki when i put in hid's. its easy and reliable. you'll figure it out. let me know if you have more questions im hear to help :)
Buck01
Ok cool thanks I'll let you know
