Kouki harness on zenki
BlakDrag0n9
Car: Nissan '95 240sx Base - '89 Maxima SE
OK after serious consideration...I'm planning on doing a Kouki conversion on my Zenki. Also I want to do an HID projector conversion on the headlights...the thing is my zenki came with HIDs and the harness was cut up. I want to use a new HID kit on the Kouki with plug-and-play connectors...but I need a new complete headlight wire harness cause my corner light are also cut to crap so the dont light. I need to know if I can just settle with a set from another Zenki or should I use the harness from a Kouki also knowing the Kouki comes with an extra relay which keeps the low beam lit when the high are active and that the Zenki uses 9003/9005 bulbs and the Kouki uses H1/9005? Your imput if any will be very appreciated
BlakDrag0n9
bump
180fan
Car: 89 fastback
cut, solder, and heat shrink will solve your problems.
- or -
if you're getting an HID kit, ask to see if the folks selling you the kit can switch out the bulb with the one you need, and keep the back end (at the ballast) to the stock one you got.
