Persona wrote:Remove the headlights and cornerlights, remove the skid/plastic panel underneath, take out all bolts visible from the top. There are now also some bolts inside the fender that hold the ends of the bumper you will probably need a flashlight and to get a little flexible with your hand. Once all the bolts are off you should be able to easily pull the bumper while lifting a little at the same time. Make sure to unplug everything from the bumper.
I cant believe i just wrote a guide to that but i'm bored. So goodluck.
Thanks for the "guide"! It should be pretty easy... It just sounds a little time consuming!
Dittoz7 wrote:Start With The Corner Lights Tabs That Hold them In Place.
Once Removed You Should See The Other Nuts Holding The Headlights On.
Awesome! Thanks for helping the new guy!
