Kouki Fog Lights
TachyonS14
Ok, I bought some SE fog lights and bolted them in, and connected the wires and put in the new blinker arm with the fog light switch. Now, I know I need to put a relay in the fuse box so they can work.
My question is, what type of relay do I need? Can I use a relay from any old Nissan? Does it have to be a certain Nissan relay? Do I have to get one from the stealership?
574-240sx
Car: Nissans, Toyotas, Subaru
Most of the time you have to go to the stealership. You can try the junkyard. I would be surprised if a local car parts store had it in stock.
s13sr20chris
some relays are interchangable. is it a blue relay? are the terminals in the shap of a cross or a box?
TachyonS14
The terminals are in the shape of a cross. Looks like it would be the same as one of the blue ones under the hood. I'm going to interchange them to see if it works.
s13sr20chris
blue relays with the same pin pattern are interchangable i promise.
TachyonS14
Awsome man, thanks a lot for your help!
