kouki check in (s14)
j6250
Car: 98 240sx
^^Damn good pic. Kuudos!
SKproductionZ
not mine but i sure wish it was lol
keep it going
props to risky devil and Chobz Kandy Red S14
hazer396
Car: 2007 Tahoe, Impala
risky devil is crazy ****
assassin7420
Car: 1996 Nissan Silvia
1995 Nissan 240sx (daily)
Bumpin it back up.
turbo2nr
Car: 97 240sx (kouki)
looks damm good assassin7420, did you lower her?
cali style car wash in nyc!
assassin7420
Thanks but, Im still on the KYB's with Eibach pros. I don't think I can go any lower due to the wheel/tire setup I want to run.
Yours looks like shes coming along nicely too.
spooled240
Car: kouki s14
assassin7420 wrote:Thanks but, Im still on the KYB's with Eibach pros. I don't think I can go any lower due to the wheel/tire setup I want to run.
what kinda wheels do you wanna run? You are only on a 1 inch drop right?
We just had a pretty crazy snow storm here in socal:
SNOW: because sometimes the air-to-air intercooler just doesn't cut it.
One for the check-in, when i still had that greddy lip =[
pinoyboy3241
Car: 98' 240sx
I love your car^
FusionR300zx
Car: 1993 300zx/1997 240sx
some1 in the s13 thread said that 20's don't belong on any s-chassis....
they should take those words back.
assassin7420
spooled240 wrote:what kinda wheels do you wanna run? You are only on a 1 inch drop right
Yep, They only offer a 1.2 in drop in the front and a 1.0 in drop in the rear. However for my tire setup works perfect.
I'm planning on running 275/40/17's all around. I've already test fitted some 17x9 +26 wheels with those tires and fitting them is STUPID easy.
The front fenders need to be rolled and have a 1 1/4 pull. The inner splash guard at the back of the tire will rub, This needs to be relocated a little further in the fender. There is also a low spot in the front of the wheel well, You just need to hammer that in no more then 1/2 an inch. I will also have to run a power steering cooler but that's not hard to make. Doing this allows me to go full lock to lock with no problems.
The rears need a roll and a 1/4 inch pull.
Also, You really need to make an OM NOM NOM picture with your car eating snow like that
FusionR300zx
is it gona clear with a tire on there?cuz i have 17x9+24's up front and didn't even clear the coilover.got a 15mm spacer.back is no problembut with the strut/spring combo isn't it a lot like wider up top with the spring?not as thin as a complete coil over setup..?
assassin7420
I thought it would rub on the bottom of the spring perch to with the larger tire, But it clears with a good inch and a half of space.
When I test fitted wheels I used 04 Cobra wheels with the tires. First took measurements of the fenders. Then did lock to lock and found the 2 small problems.
If I was lower and had coilovers they wouldn't fit, So having the spring strut combo worked out.
bigs
I finally got a lip...haha. I'm getting the jdm grill for christmas, and I am going to start saving up for wheels now.
FusionR300zx
assassin7420 wrote:I thought it would rub on the bottom of the spring perch to with the larger tire, But it clears with a good inch and a half of space.
what about when you go over a bump?cuz my sisters wrx has springs on it and the tires have patches of where it hits the spring on bumps when the strut/spring compress.be carefull about that.
ThuG LyFe
Car: 95 S14
hey andrew where is the car wash place in nyc?
also they open in the winter? i have all the washing gear but my stupid landlord turns off the water for winter so i can't wash my car...lmk man.
98koukile
Car: 1998 Nissan 240SX LE
The spring is physically above the tire... I don't see how this would happen on an S chassis
brizanden
Car: thrased kouki ftw
i like the look.. lol no seriously i like it better without that lip.
turbo2nr
ThuG LyFe wrote:hey andrew where is the car wash place in nyc?
sup man, the car wash is all the way in longisland, farmingdale area rt109, heading eastbound after you pass sunrise (rt.27) on your right hand side..
if anything hit me after the snow melts imma need a wash again lol
assassin7420
The only way the tire would contact the spring perch would be if the strut failed, Or the tire had a blow out. The only thing im worried about is the tire contacting the inside of fender under hard cornering.
spooled240
Car: kouki s14
brizanden wrote:i like the look.. lol no seriously i like it better without that lip.
you know, i sorta like the stock k's bumper also because it flows with the rest of the car better. One thing that i didn't like about the greddy lip is how is was flat on the sides(check sig) and it made the intercooler air damn a little smaller cuz of the way it mounts on the bumper. I just wanna drop my car now
FusionR300zx wrote:some1 in the s13 thread said that 20's don't belong on any s-chassis....
that looks good, but with 20's aftermarket aero is definitely a must or it will look donk status
brizanden
if ur shocks are good just get some lowering springs. it'll make a diff not slammed but def will look lower. Or get some agx's or gr-2s for a lil upgrade and then put some lowering springs on. all cheap and lowered. and handles pretty dec.
spooled240
Car: kouki s14
i have lowering springs, 2" drop y0.
Do you guys think it's still too high? I think so =/
spooled240
Car: kouki s14
assassin7420 wrote:Also, You really need to make an OM NOM NOM picture with your car eating snow like that
brizanden
really its already lowered... dam my car seems just as low lol.
VanCityGreeD
Any more info on the s14 w 20's pls? Sexi!
spooled240
Car: kouki s14
brizanden wrote:really its already lowered... dam my car seems just as low lol.
post a pic of your 4x4 and we'll compare lol
brizanden
i dont have any like ride height ones
spooled240
Car: kouki s14
brizanden wrote:
maybe not much lower, but mine's definitely lower. I can barely fit my hand between the top of the tire and the fender/qp.
lunatyk
Car: s14
Weakk...you guys need coilovers.
spooled240
Car: kouki s14
lunatyk wrote:Weakk...you guys need coilovers.
i need money period.
