kouki 5 speed owners... I NEED YOUR HELP!!
motoman399
Car: 98' wrecked (RHD coming soon) 240
ok so i posted a topic a while back about my tachometer being nuts. it wasnt working correctly. heres the link zerothread?id=394484 anyways i went to the junk yard today and there isnt much in the nissan department but i picked up a tach out of a 96 maxima that looked similar. i ended up soldering in the motor from the maxima to my 240 tach. i needed to remove the needle to do this...
now i was hoping that someone could go drive there car and in like 3rd or 4th gear go a certain mph and tell me what rpm its at. maybe a few times in two or so gears. and if your daring enough run it on rev limiter for a few seconds and tell me what thats at exactly.
thanks and i will love you long time for this!!!
Amtk240
Car: 1997 Nissan 240sx SE Red S14, and 1995 Nissan Navan 240sx Ruby Pearl S14.
Wouldn't a GPS help you? I found out my Zenki's speedometer was off by 4mph by the use of a GPS. My Kouki is dead on.
Philipio
Car: 96 240sx, 96 Miata
That's not what he needs at all. He needs to know what speeds result in what RPMs.
motoman399
Philipio wrote:That's not what he needs at all. He needs to know what speeds result in what RPMs.
thats exactly what i need. i dont need to know the actual speed. that varies by tire size.
spooled240
Car: kouki s14
i'm not gonna bounce off the rev limiter as my tune doesn't have one lol
but i remember doing about 80mph exactly at around 3400 or 3500 rpms in 5th. RPM drop between gears is 500 rpms.
motoman399
ya i could see why you wouldnt want to bounce it off the limiter lol. my car loves the limiter. if i remember right its at 6800. but im not positive. and also i think that 4th gear at 3000 exactly is 40mph. think you could try that one for me? thanks man
spooled240
Car: kouki s14
I think that 3,000 rpm in 5th is 65 also if that helps any. Are you adjusting your speedo? I think theres a small adjustment screw on the back of the speedo that you twist to adjust your speedo for taller wheels/tires/gear ratios.
yeah once i get my car goin I'll get back to you..my SSAC mani cracked and the new mani place the turbo a bit differently so it's been nothing but cuttin, grinding, welding and all that fun custom shiz.
motoman399
no im adjusting my tach cause i had to remove the needle to solder in the new motor.. but ill try that and see how close i am. by the way im SO glad you got rid of your HD lip. and got your new one painted. it looks so much better. your car looks sick!
spooled240
Car: kouki s14
i canned that shiz a long time ago, it only took me a week to realize i effed my car up. I had that greddy lip on it for a while but i busted that off through the canyons =/ so i'm back where i started lol
I thought i was gonna get my car done this weekend but UPS fuccked up
motoman399
what do you mean done. what are you doin to it? so how much psi are you running. i saw your running a blow through z32 maf i was going to do that too. also what size injectors do you have? have you gotten it dynoed?
