adidas2go »
https://forums.nicoclub.com/adidas2go-u78832.html
Thu Nov 27, 2008 8:59 am
The second number is only how thick the tire is. For example a 245/35/19 tire it about 2 inches thick. A 245/40/19 tire is about 2.5 inches thick. Keep is mind, the first tire is going to be about a 1/4 inch wider than the second, because as you increase the thickness of a tire, but keep the same dimensions, it brings the width in a little bit. Like a bow effect. I would personally go with 40's because 35's have the chance of blowing out really easy and riding rough because they are so thin. I have 35's on my troubles, when I get tires again, I will go with 40's.
