240marcuSX »
https://forums.nicoclub.com/240marcusx-u5199.html
Tue Mar 25, 2003 2:16 pm
i just put some koni yellows with eibachs in and, the front ones you have to hack off the top part before a metal piece before the chrome shaft, youll need a sharp hack saw and a vice, but be careful and try to cut straight because you will have to use the lower part of the shock,(nissan makes some hard steel) as for the rear ones i used a rubber tip hammer (dont know the actual term)and hit the spring seat off the top of the shock, you have to saw a piece off of these too to do so, there is a piece that the seat cant get over because its too small, but you dont need this piece so i sawed it half way and used a hammer.
