Knurl
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Don't know why the other thread pops up locked.
knurl   /nɜrl/ Show Spelled Pronunciation [nurl] Show IPA –noun 1. a small ridge or bead, esp. one of a series, as on a button for decoration or on the edge of a thumbscrew to assist in obtaining a firm grip. 2. a knur.
i.e. - serrations on the side of an allen hex head bolt.
Nothing to do with the driver required.
jtmroczk
Car: 2010 6-speed FJC, 1994 6-speed Q45
its a drift project, and its a q45 so i though i should ask in the q45 section?
qship96
Car: 1996 Infiniti Q45
Probobly more info in the Toys R Us section, AKA 240SX forum.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Then as I understand it, what you are asking is "What are the specifications for the spline drive of the outboard halfshaft?"
But that said, drifting is the sychronized swimming of motor sports, or more accurately, exhibition. A drift car is not a fast car, it is an ill handling car. Hence little real world application outside of the exhibition istself.
jtmroczk
maxnix wrote:Then as I understand it, what you are asking is "What are the specifications for the spline drive of the outboard halfshaft?"
its a wheel stud.
i'm asking the diameter of the spline on a Q45 wheel stud.
presidential
Car: 1992 240sx hatch, 1993 240sx coupe
This is amazing, here is what he's asking about:
It's simple. Either answer the question if you know or don't post.
NeedCAforS13
Car: CA swapped S13 coupe
Q45tech wrote:Because thread is in wrong forum = a VIP product.
How is replacing a wheel stud "a VIP product"?
Bloody hell.
Answer the man's goddam question or GTFO.
Here, I'll find it - BRB.
Google search for the following part number: O8060-169748
t appears the Q uses some fairly standard sized Nissan studs, so you can order the NISMO 50mm or 60mm extended studs from any matching vehicle.
Looks like a 350Z set will work.
NeedCAforS13
<3 you Greg. thanks buddy.
jtmroczk
AZhitman wrote:Google search for the following part number: O8060-169748
Awesome, 14.3mm it is thanks
burgy240
Car: 2000 Q45 Ann. Edition Blk on Blk
nevermind
BLACKonBLACK98
Car: Q45, LS400, STS-V
wheel studs are so vip... sheesh
you guys really need to take a second to find out what vip is if you are going to keep deciding that every mod you don't like belongs in the vip section.
that's like me saying your q45 doesn't belong in the q45 section because it's a kia. first of all your q45 DOES belong in the q45 section. secondly, it's not a f**king kia.
It's ok.
Wes and I proved LONG ago that the Q *can* be improved upon significantly... many more have done so as well...
FWIW, I switch to the NISMO studs on every vehicle I own. Why? I prefer a longer wheel stud for safety, and most OEM ones are pretty shagged after 10-15 years.
Trumpkin
Car: 1995 G50
Anyone for some HUMBLE PIE?
We'll just pretend this didn't happen.
Perfection is soooo hard to maintain.
Q451990
Kind of wondered what the big deal was myself... at least I learned what the term means... never heard of it before this.
Heath
Rex
Car: None
presidential wrote:This is amazing, here is what he's asking about:
This thread was "done" after these 2 posts.
