Knuckle spindle removal, HELP
2black240s
Car: black s13,black s14
I took a hit to the rf quarter, got body fixed, I have a bent strut and knuckle. Strut is no problem but what will I need to remove knuckle? I dont want to pay a shop 200 unless i absolutely cant do it. special tools or tricks to get out tie rod end, ball joint and hub? any help appreciated
2black240s
arrghh, now i've read my fsm and it says" if the wheel hub bearing assembly is removed, it must be renewed. The old assembly must not be re-used" and hub and bearing all comes as one. $142.37 from nissan. Do I have to replace, or is this only if I destroy it? Anyone have anything to say?
180fan
Car: 89 fastback
if the rear end was trashed, I'd probably look into a new rear hub and bearing as it's probably got fractures/bent. It doesn't all come as one part, the bearing gets pressed into the hub. The hub is about 100 new and the bearing is about 120 new. I'd probably find some rear hubs from someone parting out or someone who's done a 5 lug swap.
