I generally agree with the procedure, but I think you're confusing volts for amperage S14-NEO.S14-NEO wrote:heres a good way to find ut whats causing your draw...get a second person for this, disconnnect your neg batt lead from the battery and put a volt meter inline with the batt and the neg battery terminal.. put it on volts and check yuor voltage drop....should be less than .5 a volt...if its not which it prob isnt considering the battery dies withi one day..here is where youll need a second person. have him watch the volt meter while you pull each fuse individually. tell him when you have each fuse pulled to read out the voltage readout on the volt meter...you can find the voltage drop retty easy this way, when you find the major draw your volt meter should drop considerably...note: it could also be more than one source...
Im not sure what you meant? Like buying a new one? I think they are good, i talked to the people that did my harness and they said they have something messed up and know what it is, this goes back to my fuel pump not turning on( I had to cut the fuel relay wire and ground it out to chassis and then pull the fuel pump relay and put a jumper in to get the fuel pump to run)wagzilla260rs wrote:what dose the relay run????
rb24021 wrote:question is the battery relocated to the trunk? if so it will draw just by being back there...i personally disconnect my battery if i know i wont be driving the car for more than aday.
