0range_240 »
https://forums.nicoclub.com/0range-240-u916.html
Sun Jun 20, 2004 1:52 pm
Hey there S13.. lifters tap is either on or off, and doesnt depend on varying RPM's to be heard. I would not believe it to be a spun bearing just yet, unless the motor was run on very low oil for an extended period. To check however if it is a rod bearing, or any low end knock you can try these methods and they should give you your answer:
- with the engine running, detach the plug wire from the spark plugs on the #1 cylinder and have someone bring the motor up to the RPM range you speak of. If the noise is still there, you can be almost positive it's not a rod bearing. Repeat for every cylinder.
- also you can try listening to the engine using a stethescope or putting a screw driver to various points on the block and putting your ear to the handle to listen if the knock gets louder. I find a good way to tell if the noise is coming from the lower end of the motor, is to pull out the dipstick and listen if the noise gets louder. If it doesnt, then that indicates the problem lies somewhere else..
Once you've tried these, check to make sure your plugs are properly gapped and torqued correctly, also make sure there is no oil or liquid of any sort in the spark plug wells.
IMPORTANT READ: I had your exact same problem, I thought it was lifters at first. I even took the car to a dealer and they told me a rod bearing, although several WEEKS later, and after many high RPM runs my motor had not crapped out, as it should if the rod bearing is spun. It finally turned out that one day while I was removing my heat shield, I noticed my exhaust manifold was missing two studs! I repaired it and after tightening down the manifold properly, I noticed the sound was gone! I would strongly suggest you check your manifold, as idiot owners have a tendency to over torque them and snap them off and leave them, or they get loose over time..
I would never have guessed a loose manifold would be making a noise exactly like a knocking lifter or something of the like, but live and learn! =D
if your still having problems drop me a line on AIM : nismo1984240
peace
