Knocking sound in engine
ddred
I have a 240sx 93 fstbck, drives fine 184000 on the odometer and makes this knocking sound in the engine. Mechanic said that some nissans nake that kind of sound,,, dont sound right to me,.. any suggestions
ddred wrote:I have a 240sx 93 fstbck, drives fine 184000 on the odometer and makes this knocking sound in the engine. Mechanic said that some nissans nake that kind of sound,,, dont sound right to me,.. any suggestions
Welcome aboard!
Need more info.
Take a long screwdriver and place it at the front of the valve cover (where it meets the head) and put your ear on the handle. Is the sound more of a "clicking" coming from there? If so, no biggie. Timing chain guide.
If it's a deeper "knocking" sound, does the sound ONLY happen at idle and deceleration (but go away under load)? Test by placing it in D and holding the brake while lightly presing the throttle (or putting it in gear and lightly applying the e-brake while accelerating).
If the sound goes away (or gets quieter) under load, it's likely a bearing and you're pulling a motor out.
ddred
I did the test and the sound went away when i put it in gear, use the e-brake and accelerated. the knocking is a deep sound. when i started at first there was no sound but then after idling for 2 mins it started. thanks, so do u think its just the bearing?
sx moneypit
Car: 2010 Nissan 370Z
1986 Toyota MR2
Pull one spark plug wire off at a time and see if the knocking goes away or gets quieter. This will help you isolate the cylinder the knocking is on and tells you if you do have a bad bearing.(takes the load off the bearing).
butler86clint
Car: 92 s13 redtop turbo
im new to the forum. as well as the sr20det redtop turbo. which is what is currently in my 92. im on the second motor and this one knocks like woodpecker in the block lol. can anyone tell me what it be? rod knock etc?a it does it when i hit the gas at about 2000 rpm and just gets worse from there.
bens240sx
Car: 1993 240sx fastback KA24DE kitted
butler86clint wrote:im new to the forum. as well as the sr20det redtop turbo. which is what is currently in my 92. im on the second motor and this one knocks like woodpecker in the block lol. can anyone tell me what it be? rod knock etc?a it does it when i hit the gas at about 2000 rpm and just gets worse from there.
what you hav sounds like a rod know from a bad bearing i have been through that sound bout 2 times due to bad oil pump but i garentee you thats what it is
ddred
hey moneypit, I took it to a mechanic for a check and he is bent on telling me its the time chain that is loose. Do I run the engine while I pull the plugs individually?
ericb382
Car: 96 s14
ddred wrote:hey moneypit, I took it to a mechanic for a check and he is bent on telling me its the time chain that is loose. Do I run the engine while I pull the plugs individually?
Yes. Run the engine so you hear the knocking. Pull them one at a time. Does the knock go away with any one cylinder not firing?
htbyrico
Car: 1996 Inifiniti Q45/ Nissan President
frist check your oil for any metal flack in it!! you just might need a new motor bro hope the best to you!! sound like a rod is bout to blow!!
butler86clint
so rod knock then? so any suggestions? that joker on jdm engine source gave me a crap motor huh? what is wierd is i been giving it hell for like month and still drivin it evary day.. wouidnt it of thrown a rod by now?
butler86clint
sorry.. that was to bens240sx.. unless you know whats up wit it? am i lookin at a rebuild or new motor?
ddred
ok, here's the deal,,, I checked the oil and there is no metal stuff on it,,,(clean)I removed the plugs as suggested and the knocking sounds the same for all, did not go away... does this still sound like the rod or the chain? the mechhanic was saying could be chain and tensioner!!!-
will post any new findings
htbyrico
sent you a message on yahoo !!
ericb382
Car: 96 s14
doesn't sound like rod knock. Did you listen to it with a stethascope (or screw driver if you don't have one) like recomended?
bens240sx
does the knck get louder when the rpms go up search you tube see if it sounds like any of those 240 rod knocks and there may not always be meatal in the oil if the bearing is gone if it is early in the rod blowing
rioredstang
Car: 1993 240sx SCCA ITS
Sometimes a crack in the flywheel can make a knocking sound and goes away when in gear. If you remove the starter and look thru the hole you may be able to see a crack. Just something else to consider.
Psw Jdm
if its a timing chain rattle i could help.
ddred
thanks Bro, will let you know what I find out
david.lee264
Car: Accords, Volvo
Its not a big problem. Get it solved by related mechanic.
butler86clint
Yea, as the rpm's climb the knock get's louder.. So you think its a rod bearing?
bens240sx
yup sound like it deffenitly if its a auto put some load on it the see if it got a lil worse if it did then you have a rod bearing going
htbyrico
hey bro any luck on what i told you to do??
ddred
Ok guys the sound is a timimg chain problem, I will try post a video of the sound.below is a pic of the valve cover off, and we can see the tensioner pushed all the way in. well am hoping that this is the real prob of the sound. mechanic also said the teeth are worn so seems i need a full kit.
ddred
this is the url for the video, i havent changed it yet so i can do another vid,
http://www.youtube.com/watch?v=OUpXfhlYxMc
ddred
hey bro,did not do that yet, but this is what i did. I had the valve cover removed and the tensioner was pushed all the way in, mechanic said it is bad, also he said the sprockets are worn a bit. but most people from what I am hearing is saying it is the chain guide, so I am planning to remove it and see if the sound goes away.this is the link to a pic of the tensioner
car engine 017.JPG - 3.05MB
link to the soundhttp://www.youtube.com/watch?v=OUpXfhlYxMc
htbyrico
man i wish i seen that video befor yep that does sound like its the timming chain gide or ten, well keep my up to date bro you luck out on this 1 !!! ez fix there!! if you need anything hit me up !!
bens240sx
yep def timing chain the vid makes it somuch easier
ddred
knocking sound fixed. you guys are the best. I will post a link to the new soound and pic of the chain guide. I removed the guides 1 and 2 and I used a lubricant to loosen up the tensioner. It took about 1/2 hour to take the valve cover and camshaft cover off. mechanic was ready to charge me $1000 to do a chain job..
htbyrico
we do all work and we do it very well...because we love our Nissan !! glad you fix it bro !! good job... sorry on the late post !! :bigthumb: :dblthumb:
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
After hearing the video I was like Yup its the guide, but at that mileage you may want to do a new tensioner.
