Needsumfood wrote: ↑Sun Jun 07, 2015 2:28 pm
I've recently bought a used 2012 nissan Rogue I've been enjoying the vehicle and several features but, I have ran into a problem that has just started recently. Whenever the hazard light or the turning signals are on a knocking sound is produced in the front of the vehicle both on the left and right side. When the hazard light is on the sounds alternate from the left and right sides of the car. Other than that the car operates just fine
Hey guys,
Curious if you ever found a resolution for this.
I have have a 2011 Rogue, that literally starting doing this yesterday.
Left indicator is rapid blinking, as if bulb is out, but all signals, head light and brake light are working. When braking or at a stop, you hear an alternating knock from driver to passenger side. I've yet to check the relays, but that would be a quick fix if it's my answer.
Thanks!
