DevonD »
https://forums.nicoclub.com/devond-u85542.html
Thu Nov 20, 2008 11:24 am
That really depends on what absorber you go with. Do you have some basic mechanical skills? you can change it out yourself on a saturday afternoon to save some money. And I dont think you just want to replace the one either. you should do both fronts at the same time.
the reason I say do both at the same time is becasue if you get a cheap shock then it might not perform as well as the one on the other side. same thing with a expensice shock. its going to be stiffer and handle differently than the other shock. its like having a big beefy winter tire mounted on a 14" rim on one side then on the other side having a 18" rim with a high performance tire. they just wont mix well.
