Welcome to NICO.
Did you torque all the bolts to spec? See
BR-23. Some bolts require relatively high torque (the caliper bracket bolts for example) and if you just tighten it by feel, that may not be sufficient.
Were the slide pins and pad shims (if applicable to the pads you used) lubricated with proper brake grease?
