NisanS13turbo »
https://forums.nicoclub.com/nisans13turbo-u22252.html
Sun Jan 23, 2005 6:07 pm
Everything went well and now it was time to start the engine with out an exhaust. We had to start the engine with just the downpipe put in so im not sure if that was the problem. The engine sounds great other then the knocking noise coming from the valve cover. We couldnt see what was the problem, some problems that we might think it is are bent or loose valve, something inside valve is loose, other then that we are clueless so any help would definetly be great guys. Maybe this might help, engine has 60k, 98 Silvia motor, front clip.
