knocking comeing from motor need help ?
240crazey
Car: 1992 240sx
hey i just put my sr20det in my 91 240sx and it started right up no smoke comeing from the motor or anything but i have a knocking comeing from the front of the motor i think my valve have to be adjusted if so how do i adjusted them. , thank
inkslingers13
Car: 1985 Corolla Gt-S
how are you sure its not a knocking rod? or a spun bearing?
redtop91
Car: ↑ ↑ ↓ ↓ ← → ← → B A Start
Your valve need to be adjusted? Really? No not really. If it's a tapping noise and you still have your chain guide, start by taking that off and seeing if the sound goes away.
240crazey
Car: 1992 240sx
im not im just hopeing for the best and you still have the standalone
240crazey
Car: 1992 240sx
thank ill try taking off the chain guide and see if it gos away
driftset
Car: notch top powered s14
...yea good luck with that wheres your motors from ?
Hijacker
Car: '92 240sx Convertible
'94 F-150
One thing I think people need to remember is that these are junk yard motors. Don't expect them to be 100% factory ready.
Timing chain rattle has a definite difference of sound from a rod knock. I've even seen main bearings get ready to spin and make a knocking noise just like a rod. Usually, if the noise is low in sound, you caught the bearing before it spun and did any damage.
Knowing the difference is just one of those things you learn with experience I suppose. I can't actually describe what it sounds like, but I could pick it out if I were standing there.
wingFeather
Car: Current: 05 G35 Coupe
Previous: M35, M35 Sport, cube, J30, s13 sr20det, s13 rb20det, s14 zenki
Hijacker wrote:Timing chain rattle has a definite difference of sound from a rod knock.
I've got a metallic sound, almost like a loose bracket being tossed around inside the engine somewhere. Only shows up when engine is warm & the beat is not consistent.
Could this be the timing chain guide???
I've been told that rod knock is consistent in beat, and sounds like someone knocking on a wood door. Is this true?
Thanks x 1,000
driftset
just pop the chain guide off and hope for the best its easy enough to get to...jus dont drop your nutsss when your in there!
and yes a rod knock is usually constant it does kinda sound like the devil knocking on a wood door just hide from em like a johova's witness
redtop91
driftset wrote: and yes a rod knock is usually constant it does kinda sound like the devil knocking on a wood door just hide from em like a johova's witness
WOW. I don't even know where to begin on this post. Oh yeah I know now. First off it doesn't make ANY sense. Second off you misspelled the name O great ignorant one. It's Jehovah's Witness. 3rd off of what relevance was any of that to the issue at hand? Besides restating what everyone already knows you contributed nothing with that. Thanks.
driftset
yea the issue at hand was a very unspecific question to a problem that can be millions of things the fact that he thought he could ajust the valves in this motor leeds me to belive this is all quite new to him. i never claimed to be an expert,i come on here and learn as much as i can from the "inteligent" posts and was making light of a problem which iv already gone through myself. il keep in mind that theres people in here like you that moderate and evaluate every single word in here to keep it as informative as it is. thanks for your expansive knowledge guy please for give me ; the most iggnorant 1
WoolyS14DET
Car: 1998 Nissan 240sx w/SR20DET
Are you sure that the lifters arent pumped up yet due to the motor sitting for so long ??? How long did you let the motor run before you shut it off ??
wingFeather
redtop91 wrote:Besides restating what everyone already knows you contributed nothing with that. Thanks.
His post helped me
