knock when coming to stop, diff bushings bad?
cyrus240sx
Car: 95 240sx with five lug swap, rims, suspension, I H E, remote start, too bad its auto
now ever since i bought my 240 (about a year ago) when ever i would come to a hard stop, right at the end of it i would hear a thump from the rear of my vehicle. i didnt think anything of it until i had my friend in the car and i made a hard stop and he heard it and said that my diff bushings might be bad....Anyone know if this is true or if anything else could be bad?
btw this is on a 95 240sx, abs, auto,vlsd, ~150K miles..
Thrwnsprkz
Car: 240sx
rear subframe bushings? mine thump when i run the car anything but smoothly, just my 10 cents...
n00b240
Car: '03 6MT
Either subframe bushings, or differential bushings, or both. I just replaced mine because of that problem, all bushings are aluminum now
solo
Car: 93 Nassin 240sx
I justed got a 95 240sx and having the same knock in the back of the car. I worked at nissan and we put all new subframe bushings. it was easy to do.No more knock.
95nismo240
Car: 1995 Nissan 240sx
my 95
solo wrote:I justed got a 95 240sx and having the same knock in the back of the car. I worked at nissan and we put all new subframe bushings. it was easy to do.No more knock.
my 95 240sx is doin the same thing... are the subframe bushing located only at the rear of the car???? also, what can get messed up if u dont fix this problem???
n00b240
Car: '03 6MT
Basically knocking will get worse, the rubber will wear away and you will heat it all the time. Subframe and differential can get dented out of form (after a really long time) and alignment goes out of wack, causing uneven tire wear
Thats about all I know
pacman88
Car: 1996 240SX SE
I hear a knock when I reverse (fast) and when I brake hard. I have 168K+ so I'm sure that the bushings are shot. Would I benefit with collars?
n00b240
Car: '03 6MT
Hmm maybe , but if the bushings are shot, I would guess that might now help too well. Anyone else...Nismo_Freak what do you think?
