SouthO_Czch »
https://forums.nicoclub.com/southo-czch-u163208.html
Wed Nov 10, 2010 12:18 pm
Really? Great advice. I was looking at the shop manual, and the way i understood the procedure it was an all or nothing removal. Im kinda screwed due to the fact i work in Albany, GA and live near the coast south of Tallahassee, so when im away i dont have any tools or a place to work on her. As far as I know the timing belt has never been replaced. There have been some other gremlins popping up as well. In the morning she has a problem getting fuel, or at least it seems as such, but works itself out. i have been getting crazy oil pressure readings, all over the map, from the stock OP gauge; read this Z is notorious for having this problem and I should replace the sending unit. And lastly, driving early morning hours with temps in the thirties, my stock temp gauge was reading almost completely rock bottom. She seemed to run fine, and didnt notice any other problems, but I couldnt believe it was running so cold at 65mph on the highway. Cant imagine its a head gasket; this car burns no oil, loses no coolant and stays clean, and has never smoked. Thanks again for checking my posts out. Any input is appreciated. i have just put the Z in a trusted shop and Ill report back with their input, so maybe it can be of help to someone else down the road (no pun intended).
