Left or the Right?
J30_Kidd
Car: 95 J30 Pearl White
Hey Guys, as you might have seen on my other post I recently redid my engine seals and such and put a new knock sensor which ended up not working (cheap eBay one) :ohnoes2 . So I'm gonna order a genuine Nissan part this time instead of a cheap one and I'm relocating it up top cause i don't wanna pull this engine out again. :mad:
ANYWAYS! I didn't feel like spending another 40$ on a sub harness again so i jabbed my hand down there and pulled on the new one and was able to get it off and fished it out, the down fall was the wire inside popped out of the plastic piece but the female pin didn't rip of the wire, whew! Heres my problem, there's two holes in the plastic connector but of course one wire and i'm not sure which hole it goes into. looking at my old sensor it seems the connector would of been on the left side due to it haven less corrosion on it (see pictures below) So i went ahead and inserted the pin back in on the left side of the harness for now, I just wanna clarify if i put it in the right spot, I'm hoping someone whom has done this relocation can pop there plug off and check to see if i got this pin in the right spot. :biggrin: :biggrin: :biggrin:
J30_Kidd
Ok so no one responded so i went ahead and took a gander at a few at the local j/yard while getting a compressor for the j today.
What i saw is that it is located on the left side as my pics show. Hopefully this helps someone out in the future so they don't go through what i did just to verify what hole it's in.
Thanks
