maxnix »
https://forums.nicoclub.com/maxnix-u127.html
Sat Dec 27, 2008 5:08 am
Buy it all as you have to remove it all to get to the KS and its subharness.
Install new parts on the way back out for the same labor. Clean plenum, TB,IAC and EGr valves and lower runners while you ar ethere to as new clean. Consider plugs and VC covers if not repalced in last 20K or 3 years. Add water pump and thermostat if not changed in similar period. Cahnge to OAT coolant and distilled water.
You should be good for another 80K -100K or ten years if you keeep on top of fluids and filters.
