Q45tech »
https://forums.nicoclub.com/q45tech-u112.html
Mon Apr 02, 2007 12:54 pm
Retarded is confusing some.......................the total advance is the SUM of the initial advance [set by CAS] plus a group of individual cell locations.
The maximum advance is like 40 BTDC at cruise and 26-28 BTDC at WOT above 6500 rpm.
The KS circuitry is not smart enough or fast enough to operate much above 4500 rpm .
THE KS may add anywhere from 0 to 12 degrees so retard is not really the correct word....................less than normal is a better explanation.
At WOT the KS is pretty much ignored and the ROM takes over to supply the advance.
The ecu test KS system during idling for signals and proper resistance.
If resistance is not correct it throw s a code if signaling is not correct it set a midpoint [the regular fuel chart say a 3-6 degree decrease from full 12 degree advance.............it still listens for knock and will still decrease more if it hears any .....................most simple knock occurs 1500-2500 rpm during sudden more throttle open transitions..............when the cruise advance needs to drop from40 to 20 to accelerate.
The knock occurs because the throttle is manually opened and there is a delay between MAF and TPS resolution.
