alexander wrote:Infiniti tech road tested again both fuel pressure and KS's and that when the codes came up for failed KS. They replaced them but that was not the problem. They did not say this could be the 'only' problem.
The KS are supposed to throw a code to the ECU when they sense something out of range going on with the engine (fuel starvation?). The fact that they threw the code when the timing advanced tells you that they are working, not that they need replacing. If they really were dead a simple 5 minute test with a voltmeter would have confirmed it:
Is there some scrawny 10 year old with long arms that you can put in your trunk and have them reach in and unplug the FPCU to check the connection? You'd probably only have to remove one plastic screw in the trunk trim to get an arm in there. The FPCU is in the pic mounted to the right of the storage box near the PS speaker. My guess is that the connector on the FPCU will have scorching or burning which means you should be replacing the FPCU (and fuel pump).
If you do find a bad connection slip the kid a $20 bill because the stealership would have charged you $100 to do it.
Thanks Jared for the suggestion about Picasa. I got myself set up with an account and am back to posting pics.
