http://www.fs.isy.liu.se/Publi...J.pdfh ... AQ...lay=2
"Under warm cruise (closed loop) strategy, EEC will push the spark advance out to the point where trace knock is detected, and then back the timing off slightly, to keep away from pre-ignition. This strategy makes sense to get the most efficient burn and the most power. Under these conditions, you may hear some knock if you mash the gas, because it takes EEC a few CPU machine cycles and crankshaft rotations to drop out of closed-loop strategy and retard the timing.
Under wide-open-throttle (WOT) conditions, EEC is not looking at the knock sensor because the engine is simply making too much noise for the knock detection strategy to filter out the knock signal from the noise. Timing and fuel for WOT is derived from lookup tables that are vectored primarily by crankshaft RPM and engine coolant temperature, and to a much lessor degree by the mass air signal.
Under most conditions, EEC should be able to get the most out of any reasonable fuel that you pump into the tank, however, an especially bad load might be beyond the range that the spark lookup tables can compensate for, so pulling the octane shorting bar invokes a new set of tables, with less aggressive spark advance curves for WOT operation."
http://www.intersil.com/data/an/AN9770.pdf
