Thanks buddy!!! I forgot all about eBay. I will go on there right now. Two more quick questions after readign some previous posts...elwesso wrote:sensor 2 is going to be the downstream one, after the cat.. bank 1 is the drivers side.
you can get the KS from ebay, all 90-01 nissans use the same one, 22060-30P00 I believe is the correct part number...
I never said that it had anything to do with knock sensors, but I did think that bad gas could cause failure with O2 sensors. As far as time and mileage being a factor for failure...I think that everyone knows that!qship96 wrote:Ethanol had NOTHING to do with your knock sensors or O2 sensor failures!!!!! Heat,time,and miles are the reasons both fail.
Bro I'm riding on a bad Knock Sensor also, it's about ~$130 for 2 of them. That's the good news...the bad news is I was quoted at $1400 for parts and labor! That is why I've learned to deal with it. I don't know how handy you are, but from what I've read, it takes roughly ~ 10 hours of work and you have to take apart A LOT. I'm not that handy, so I'm going to wait 'till I save up enough money to get it done and at the same time, I'll get the Knock Sensor harness replaced, all the plenum hoses and some other parts that need replacing. Good luck and let us know how you make out.NightRiderQ45 wrote:I never said that it had anything to do with knock sensors, but I did think that bad gas could cause failure with O2 sensors. As far as time and mileage being a factor for failure...I think that everyone knows that!
The only thing that I need to know at this point is if there are two knock sensors per bank...4 total or one per bank, 2 total? The failed ks was bank 1 sensor 1 which is located on the driver's side. After looking at fsm, the pic looks like there are only one per bank but when I looked up the part on various site and even Autozone, it states that 2 are used...as if I need to purchase two ks for bank 1.
Any help will be greatly appreciated. I can change out the 02 sensor myself once I have the car lifted to change my oil.
Thanks BAndy! This is exactly what I needed to know. I've been searching the site for KS but my search came up empty. I will search KS under your name. As far as the o2 sensor, I can change the one behind the rear cat myself. I just have to get to it. It only makes since I'm guessing....is to go ahead and change both of the KS since everything will be broken down. Andy, I'm not in OK anymore...actually have a new engineering job with Southern Company in Birmingham, so how about we set up a time and I can pay you to do mine in Atl I'm willing to get my hands dirty with you also!bullittandy wrote:I have a set of new knock sensors off ebay and a good used set. Obviously both have with them their respective risks but. . .
Look for my old post on changing the knock sensors-book labor is removing the plenum but it can be done by just removing fan, alternator and a hose buried deep under the plenum.
As for O2 sensors, the rears are a piece of cake, the front passenger is not too bad from the top but the driver front -oh man.
But there is a trick. Remove the master cylinder and brake booster and let them dangle in the engine bay. You don't have to remove the brake lines as there is enough slack in them to move the whole assembly out of the way and then front driver O2 sensor is a snap.
Getting the bolts back onto the brake booster inside the car under the steering wheel was tough on the upper passenger nut but i did it by taping it to my finger.
Good luck
Are the KS new or used?UNISA JECS wrote:I got two good knock sensors. $100 paypal/shipped for both, let me know, thanks.
Picture:
Proof would help.
