Knock sensor wiring
infinityis
I'm in need of the wiring harness for the knock sensor for my 24KADE. The dealer is charging an arm and a leg, and I cannot in good conscience spend that much for a few short wires. Anyone have one they're willing to sell, or has anyone successfully done a custom replacement--I would but I don't know if the engine heat would be a problem or anything...
Thanks,David
Nismo1182
Car: Z06
The sensor with the plug? I have a spare one I would sell.
infinityis
Well, I don't so much need the knock sensor itself but rather the wiring (about two feet of wire with the plug ends). If you're not willing to sell just the wiring, how much would you want for them both?
Nismo1182
Car: Z06
I have the sensor, which goes on the block with a 10mm bolt. The sensor and about3" of wire and a plug is one piece. I think I have the other end from a chopped up harness. I'll get back to you on that.
