knock sensor wiring
ca18datsun510
Car: bmw 330i zhp, 91 infiniti m30, 89 240sx, 07 zx6r, 05 trx450r
your knock sensor wire is in the upper engine harness.
you do not have to run a wire and splice it into one coming out of your ecu.
the wire coming out of the ecu already goes to the engine bay, to where the battery is.
why would you splice into a wire that already goes where you need it to be and have 2 wires?
float_6969
You got me. I assumed people knew this and were doing it. That's how I had mine hooked up when I did it.
Masterdebater
Car: 1989 nissan 240sx coupe
might as well drawme a picture i hate wiring and all wires should burn in heck
ca240sxcoupe
Car: 1989 240sx w/ca18det, 1978 Datsun 280z
i agree, so what you need to do is find a shielded wire that has continuity when the key is in the run position and then you splice in your knock sensor wire using SHIELDED wire from either your ka or any other source just make sure the wire is SHIELDED
